How to create a module
Last Post 2006-01-28 09:24 AM by Lee Sykes. 1 Replies.
partha sarathiUser is Offline
2006-01-28 03:35 AM
How to create module in dnn. i want very urgent ple.
2006-01-28 09:24 AM
There are several free tutorials available to help you create a module. I've listed them in the Resources section of the website. You can view a list of tutorials here: How to create a module in DotNetNuke
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
I'm confused by this, too.
We are running DNN 6.x
