Greetings,
Recently I upgraded from 4.9 to 5.14 after I saw there was an alert for a "Critical Update". I proceeded to update as I usually do and everything seemed to go well until I tried to access the host settings which is when I received the following errors:
Error: Host Settings is currently unavailable.
DotNetNuke.Services.Exceptions.ModuleLoadException: D:\DotNetNuke\DesktopModules\Admin\HostSettings\HostSettings.ascx.vb(268): error BC30456: 'IsWebFarm' is not a member of 'DotNetNuke.Entities.Host.ServerController'. ---> System.Web.HttpCompileException: D:\DotNetNuke\DesktopModules\Admin\HostSettings\HostSettings.ascx.vb(268): error BC30456: 'IsWebFarm' is not a member of 'DotNetNuke.Entities.Host.ServerController'. at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVPathBuildResult(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at System.Web.UI.TemplateControl.LoadControl(String virtualPath) at DotNetNuke.UI.ControlUtilities.LoadControl[T](TemplateControl containerControl, String ControlSrc) at DotNetNuke.UI.Modules.ModuleHost.LoadModuleControl() --- End of inner exception stack trace ---
Upon checking the error log I received this entry.
ModuleId: 327
ModuleDefId: 72
FriendlyName: Host Settings
ModuleControlSource: DesktopModules/Admin/HostSettings/HostSettings.ascx
AssemblyVersion: 5.1.4
PortalID: 0
PortalName: My Website
UserID: 1
UserName: host
ActiveTabID: 16
ActiveTabName: Host Settings
RawURL: /tabid/16/portalid/0/Default.aspx
AbsoluteURL: /Default.aspx
AbsoluteURLReferrer:
UserAgent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; GTB6.3; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET CLR 1.1.4322)
ExceptionGUID: 56e7b314-a1c4-4726-ac29-34ef3666453b
InnerException: D:\DotNetNuke\DesktopModules\Admin\HostSettings\HostSettings.ascx.vb(268): error BC30456: 'IsWebFarm' is not a member of 'DotNetNuke.Entities.Host.ServerController'.
FileName:
FileLineNumber: 0
FileColumnNumber: 0
Method: System.Web.Compilation.BuildManager.CompileWebFile
StackTrace:
Message: DotNetNuke.Services.Exceptions.ModuleLoadException: D:\DotNetNuke\DesktopModules\Admin\HostSettings\HostSettings.ascx.vb(268): error BC30456: 'IsWebFarm' is not a member of 'DotNetNuke.Entities.Host.ServerController'. ---> System.Web.HttpCompileException: D:\DotNetNuke\DesktopModules\Admin\HostSettings\HostSettings.ascx.vb(268): error BC30456: 'IsWebFarm' is not a member of 'DotNetNuke.Entities.Host.ServerController'. at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.Compilation.BuildManager.GetVPathBuildResult(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at System.Web.UI.TemplateControl.LoadControl(String virtualPath) at DotNetNuke.UI.ControlUtilities.LoadControl[T](TemplateControl containerControl, String ControlSrc) at DotNetNuke.UI.Modules.ModuleHost.LoadModuleControl() --- End of inner exception stack trace ---
If anyone has any ideas as to what might have cause this I would be grateful for any advice. Thanks in advance.
Rob
