IMG ‘closing tag’ being omitted
Last Post 2010-04-27 08:55 AM by sped. 12 Replies.
spedUser is Offline
2009-12-18 12:09 AM
I have a problem with an IMG ‘closing tag’ being omitted from code for a Container.
I've added the following line of code in the Container - links.ascx :
< h3 >< img alt="Links" border="0" src="<% =SkinPath %>images/links.gif" />< /h3 >
The problem is the IMG closing tag is being omitted when it is rendered within the browser, therefore it is not validating with w3
It is being rendered as follows:
< h3 >< img alt="Links" border="0" src="<% =SkinPath %>images/links.gif" >< /h3 >
Is there any way to prevent the IMG closing tag from being omitted so it is correct HTML markup and also validates correctly?
2009-12-18 10:43 AM
I have not come across that problem before - Could you attach your container?
It sounds as though there maybe a mistake in the html somewhere.
The best way to check is to use Visual Web Developer Express, with the container file open in VWD go to the View menu / Error List - check to see if it gives you any errors
spedUser is Offline
2009-12-19 05:09 AM
Hi Lee,
I’ve attached the container file for your viewing.
1121894944471.zip
spedUser is Offline
2010-02-01 01:01 AM
Any idea why the IMG closing tag is being omitted when rendered?
2010-02-02 01:27 AM
Is this any img tag, or one specifically?
spedUser is Offline
2010-02-02 03:12 AM
It only occurs with the image tag in the Container (as attached in the earlier reply).
spedUser is Offline
2010-02-23 01:11 AM
Any ideas on how to resolve this issue?
spedUser is Offline
2010-03-23 01:29 AM
would anyone be so kind to help solve this issue?
thanks
WinXnetUser is Offline
2010-03-24 01:41 PM
try changing editor area to Basic Text Box and selecting raw (I have had good luck with this).
Experiment with the different render modes if this does not work.
GeishaMX ^_^
http://www.winxnet.com Emerson Bruce - http://chayadigital.wordpress.com
spedUser is Offline
2010-03-26 01:59 AM
thanks for your reply WinXnet, but this issue is related to the code within a Container; not adding images in the FCKeditor.
2010-04-12 04:40 PM
looking at the code in your attachment, I'm not sure why this is happening. I have not come across an image tag losing its closing tag.
Do you have a link to a live website where we can view an example of this in action?
Have you tried
< img alt="Relevant Links" border="0" src="< % =SkinPath %>images/relevantlinks.gif " >< / img >
so you place an actual closing img tag rather than / >
I have never had to do that before, but it could be worth a try, thanks,
kaushalUser is Offline
2010-04-15 01:47 PM
just try once to render container without writing the SkinPath to make sure - that is not creating any problem. Your might get some work-a-round then:
Relevant Links
Mocrosoft MVP [.NET/ASP.NET]
spedUser is Offline
2010-04-27 08:55 AM
For some unknown reason the issue has corrected itself even though no changes were made – it’s now validating correctly.
I will advise if it resurfaces.
Thank you to everyone that had a look at this for me.
