Add new portal -new portal administrator login unable to access admin menu
Last Post 2010-11-12 01:19 PM by Joseph Craig. 7 Replies.
dpssUser is Offline
2009-12-04 11:26 AM
    I have a portal named portal#1 in DNN. I have added a new portal called portal#2. While creating portal#2 i added a new admin called admin#2.
    However when i login with Portal#2 with admin#2 credentials i am unable to access the admin menu. I logged off portal#2 and logged in once again with superuser (host) account. Now i was able to access Host menu.But i am still unable to get access to admin menu. I need the admin menu to change some site setting & page settings
    Any suggestions on how to overcome this? Thanks in advance
    dpssUser is Offline
    2009-12-04 11:29 AM
    Just to add to what is written above - admin#2 was created while creating portal#2.(While creating a new portal we are prompted to add a admin)
    2009-12-04 02:59 PM
    Which version of DotNetNuke?
    Does Portal #1 work just fine?
    dpssUser is Offline
    2009-12-04 07:00 PM
    Portal#1 works fine. The admin and host logins work well. The issue ijavascript:WebForm_DoPostBackWithOptions(new WebForm_PostBackOptions("dnn$ctr419$NTForums$AF_TopicView$amQuickReply$lnkPost", "", true, "", "", false, true))s with portal#2. We are using DNN 5.1.4
    2009-12-05 01:26 AM
    You might want to try upgrading to 5.2.
    dpssUser is Offline
    2010-03-09 12:38 PM
    I am re-opining this topic. Will  this issue will be resolved if i upgrade to 5.2 ? Is there no fix for this in DNN 5.1.4. The weird thing is that even the 'host' login cannot access the admin menu. Whenever an admin menu item is clicked it gets redireceted to the home page. Is there something that can be done at the database level to get this resolved. Migration to 5.2 would be the last option for me
    Thanks in advance
    Michael CarrinoUser is Offline
    2010-11-12 06:41 AM
    This is really weird: I can't seem to find anywhere to make a new portal using Community version 5.05.01. I swear on earlier versions of DNN there was a plus sign or something but for the life of me I can't find a place where I can add a new portal. Does anyone have have a suggestion? I certainly hope the community edition allows for multiple portals -- yes? HELP! thanx.
    2010-11-12 01:19 PM
    It's on the Host, Portals page. The links are rendered only if you are in Edit mode.
    DNN nav issue by imran shaikh
