Add content with other role than administrator
Last Post 2009-12-07 07:31 AM by QDelft. 4 Replies.
QDelftUser is Offline
2009-12-02 01:51 PM
Hello Everyone,
As said in the subject I am trying to get users who aren't in the administrator role to add content to a page. I have been searching for a while now and all I can find is explanations for users for how to edit content but not how to add content.
Could somebody point me in the right directions? Thanks in advance
2009-12-02 03:11 PM
Do you want others to be able to add modules to a page? If so, you have to give them page edit permissions.
2009-12-02 03:25 PM
Posted By Joseph Craig on 02 Dec 2009 9:11 AM
Yes that is what I would like to do. I gave this user role page edit permissions (Page > settings > Permission > Edit Page is checked for this Role).
When I logon with a user in this Role, I am able to edit the page. But when I want to "Add New module" the Module dropdownlistbox doesn't contain any modules.
Am I missing a permission setting which enables this dropdownlistbox to be filled with modules?
I added a screenshot with the empty dropdownlistbox
PS. thx for replying.
2009-12-03 10:32 PM
Sebastian Leupold answered a similar question over on the DotNetNuke forums. You need to go to Admin :: Extensions, edit the module, and grant "Publish" permissions for the module. Once you get there it's easy as the section is labelled "Deploy Module" or very similar wording.
2009-12-07 07:31 AM
Yes, that was the missing factor. Thanks for the help!
I will keep that in mind, when I have another question to look there as well.
