Custom 404 error message for ASPX
Last Post 2010-01-03 12:31 AM by Joseph Craig. 2 Replies.
ChipUser is Offline
2009-12-02 02:52 AM
Does anyone know how I can display a custom error message for an HTTP 404 error associated with an .aspx page?  If I type http://mydomain.com/an-incorrect-page.aspx I get the standard error page.  I would like to do one of two things:
1. have any incorrect page redirect to mydomain.com/home.aspx or if this is not possible/practical
2. have a custom .aspx page that they see.
I know how to customize the html error messages, but not these.
Thank you!
Chip
BCRoseUser is Offline
2010-01-02 07:16 PM
Bump
I am looking for information on this as well.
2010-01-03 12:31 AM
I found one solution here.  Google for others.
