HTML/Text module not available
Last Post 2009-12-10 12:31 PM by Lee Sykes. 6 Replies.
CorbitUser is Offline
2009-11-13 10:30 AM
I have created a user in a portal, who should be able to create content to the site. When the users log on he can not see HTML/Text in the list of available moduls - he can only see a few modules. If I add the user to the Administrators group there is no problem. Any suggestions?
2009-11-13 02:06 PM
Can he actually add other modules to a page?
2009-11-14 12:01 AM
Yes he can see and add 4 modules (Account Login, Banners, Feed Explorer, Search Input and Search Result). He has no problems in editing existing HTML.
2009-11-17 03:33 PM
I have the same happening in DNN5.1.4 - it appears as though this configuration has recently been changed in DNN 5.
A user who is given edit permissions for a page can edit the modules on the page and edit the page settings, however they do not have the option to add modules to the page. When I have logged in as a user who has access to edit the page, no modules appear in the module drop-down list.
Modules can only be added to the page by users who have administrator access.
2009-11-19 05:15 PM
If modules only can be added by users who have administrator access, then I think It's strange that the user can add 4 modules? Do you think there is an error in the program?
2009-11-23 01:02 PM
I solved the problem, by manually adding the correct permission values to the database table DesktopModulePermission. Does anybody know if these permission can be maintained through the web interface?
2009-12-10 12:31 PM
Just to follow up, there is a new configuration in DNN 5 for this:
Go to the admin menu / extensions
not host menu
Click on the edit pencil icon for a module, from there you can set which security roles have access to the module
