How to Limit Access to Administrator Modules in DotNetNuke 5 - issue 50
Last Post 2011-03-18 03:04 AM by Joseph Craig. 24 Replies.
Page 2 of 2 << < 12
Guru DigitalUser is Offline
2010-07-19 04:29 AM
Thanks for this tutorial but I have a problem as I have the latest DNN Community edition installed and the admin modules do not appear on the module drop down list when trying to add them following this tutorial. I am logged in as host.
Any ideas, please?
Colossus ITUser is Offline
2010-08-10 02:47 PM
Hi Lee that was a really good tutorial helped me loads.
One question though, I've now given staff members ability to add users, and give them roles, all good stuff and in a days work for them managing user access to the website. However they can also now see the 'Manage profile properties' link which I don't really want them playing about with. Presumably to change this I need to dive into the DNN code and switch off the link if they are not administrators. Can you advise where to start on this? I'm experienced in asp .NET but not had a go at customising the DNN code.
Any pointers gratefully recd or maybe you've addressed something like this elsewhere  in another tutorial
Many thanks
Rob
Joseph CraigUser is Online
2010-08-12 03:05 AM
Rob,
If you are lucky, you'll be able to modify the .ascx page to use some server-side processing to suppress that, or other, link or code.
I would recommend that you give your staff members a role like "staff_admin" and use that.
Follow this link over to Snapsis.com for some really good ideas.  Remember that what you can do in a skin you can also do in an ascx page.  I'd do some conditionals to make remove the links for people not hosts or admin.  That would include staff_admin.
Remember that any changes like this are changes to the core code.  They won't survive upgrades, and you will have to do them after upgrading.  And, the ascx may change.  So, save code, save notes, etc.
Jan HorniakUser is Offline
2011-03-17 08:24 AM
User in Member of Staff role see in Pages(tabs) module also administrator’s pages (even user can delete admin pages), this is wrong.
Is here some solution to limit seen admin pages for this user?
2011-03-18 03:04 AM
Perhaps you want to give Staff privileges to only modify modules?
Page 2 of 2 << < 12
RE: Deploying dnn by Sameer
Just sent it.
