PowerDNN OpenForce Giveaway!
Last Post 2009-11-02 02:17 AM by Mr. MobileNow. 0 Replies.
Mr. MobileNowUser is Offline
DotNetNuke Ninja
2009-11-02 02:17 AM
    PowerDNN has been the leader in DotNetNuke hosting and services since the beginning.  We're really excited about the future, and as part of the DotNetNuke OpenForce conference, we would like to share with everyone. Welcome to the PowerDNN OpenForce Giveaway!
    Starting Monday, November 2nd through Friday, November 13th, PowerDNN will be giving away 5 packages of Omaha Steaks, 5 ZUNE HD's, and two Panasonic 50" Plasma HDTVs!
    This giveaway is open to everyone in the DotNetNuke Community - Even if you're not hosted with PowerDNN!  We want to get the word out about our world-class hosting and technical support.  Spread the message and you could win big prizes!
    To Register for the giveaway, visithttp://powerdnn.com/Home/TheOpenFor...fault.aspx
    -Tony Valenti
    DotNetNuke DNN Hosting
    DotNetNuke DNN Hosting UK
    I work for PowerDNN
    RE: DNN 6.2 by Joseph Craig
    DNN 6.2 by Sameer
    RE: Deploying dnn by Sameer
    Thanks a lot so kind of you
