can I determine if the user is admin using JavaScript
Last Post 2009-10-29 03:57 PM by Joseph Craig. 1 Replies.
HaiderUser is Offline
2009-10-29 02:35 PM
Hi there, I've used the following VB to determine if the current user is in an admin role: <% If Not PortalSecurity.IsInRoles(PortalController.GetCurrentPortalSettings.AdministratorRoleName) Then %> however i was wondering I could do the same with JavaScript on the client? Thanks
2009-10-29 03:57 PM
You will need to write out the role somewhere from the server into the page so that you can use javascript to grab it. Is that enough of a hint?
DNN nav issue by imran shaikh
