How can I put a link with text in Form and List
Last Post 2009-11-26 05:13 AM by sped. 3 Replies.
shragaUser is Offline
2009-10-29 12:40 PM
    I need to display a link in Form and List module with a descriptive text where it takes the text and the url from the database (as you'd get in text-field).  is there a way to achieve this?
    thanks
    2009-10-29 08:14 PM
    I ended up resolving it by putting the text in one cell, putting the url in a div in a hidden cell and using javascript window.location on onclick on the text cell. shraga
    spedUser is Offline
    2009-11-19 02:04 AM
    I have created an example table as below:
    Book Title Description Release Date
    Harry Potter This book chronicles the events directly.. 21/07/2009
    I’d like to be able to enter the book title (Harry Potter) and link the actual title name to a sub page on the website.
    Is this possible with the Form and List module?
    I want to avoid creating another Column with URL option and having the page listed/url listed.
    Thank you
    spedUser is Offline
    2009-11-26 05:13 AM
    Here is the answer:
    Calculated Column
    RE: DNN 6.2 by Joseph Craig
    DNN 6.2 by Sameer
    RE: Deploying dnn by Sameer
    Thanks a lot so kind of you
