Microsoft Project Server Module
Last Post 2009-10-28 02:52 PM by Joseph Craig. 1 Replies.
Vedad DedovicUser is Offline
2009-10-28 04:24 AM
Hello All,
Is there a module or a way to integrate MS Project Web Access into DNN, similarly it is integrated with Share Point Services.
Vedad
2009-10-28 02:52 PM
You might look at this module (found on Snowcovered.com):
SigmaEX v1.0 Source Code (D3) MS Project Converter by OnyakTech (3/26/2005)
SigmaEx allows you to share Micrsoft Project files through your portal with direct interaction to the tasks. Manage and edit tasks directly though your portal, then with the click of a button you can download from your portal to Microsoft Project. Edit tasks, check out the Gant chart, etc.
