filtering in Forms and List Module
Last Post 2010-05-12 04:20 PM by Joseph Craig. 3 Replies.
AnthonyUser is Offline
2009-10-20 10:27 AM
Hi, The filtering capacities of the Forms and List module are pretty basic. I need to implement a filter scenario like on this site: http://www.fie.ch/Competitions/Cale...mnuCompCal Does anybody know a commercial Forms and List module with more filtering capabilities. Thanks in advance, Anthony
2009-10-20 03:10 PM
Take a look at SQL Grid Selected View from tressleworks.ca.
cube consultingUser is Offline
2010-05-12 03:51 PM
I was wondering if there are any tutorials on the forms and list module... I can't seem to find any! Thank you Aad
2010-05-12 04:20 PM
Look at this one:
UDT was the former name of the Form & List module.  There is also a fairly decent manual for version 5.1.2 of the module.  You can download it from CodePlex.  It has some simple examples that are easy to follow.
