Child Lists (re: Countries and Regions) [Please Help]
Last Post 2006-11-03 11:33 AM by Lee Sykes. 4 Replies.
David StaceyUser is Offline
2006-11-02 10:07 PM
With reference to my previous post (Countries and Regions)
I have discovered what i need to do to create a region list for the UK (or any other country, for that matter) is to create a child list of country. However, the problem i have is that the 'Parent List' and 'Parent Entry' fields are greyed out (disabled).
What can i do about this?
Many Thanks
Dave
2006-11-03 08:15 AM
Hi Dave,
This looks like a bug in 4.3.x - I've just done some research in the main dnn forums, have a look here:
http://www.dotnetnuke.com/Community...fault.aspx
and I've just posted here:
http://www.dotnetnuke.com/Community/ForumsDotNetNuke/tabid/795/mid/2108/threadid/61060/scope/posts/Default.aspx#81753
In a 3.1 installation you can select the parent list, in a 4.3.x installation you can not select the parent list.
I would go to the above post and tick 'email me' when someone replies to see if anyone from the core team replies to my post,
PS. - If you carry on a thread from one of your earlier posts, can you reply to your first post, otherwise it will become confusing for anyone else searching through these forum. - cheers
2006-11-03 10:17 AM
Thanks for your input, Lee its greatly appreciated.
I was up most of the night, last night trying to figure out why the Parent List and Parent Entry lists were disabled.
After going through all the settings i could find, and think of on the Admin and Host menus, to no avail. I thought it needed a more logical approach, so i started by viewing the source. and discovered the following markup:
<tr id="rowSelectList" runat="server">
<td class="SubHead" width="160"><dnn:label id="plSelectList" text="Parent List:" runat="server" controlname="ddlSelectList"></dnn:label></td>
<td><asp:dropdownlist id="ddlSelectList" cssclass="NormalTextBox" AutoPostBack="true" Width="240" runat="server" Enabled="False"></asp:dropdownlist></td>
</tr>
<tr id="rowSelectParent" runat="server">
<td class="SubHead" width="160"><dnn:label id="plSelectParent" text="Parent Entry:" runat="server" controlname="ddlSelectParent"></dnn:label></td>
<td><asp:dropdownlist id="ddlSelectParent" cssclass="NormalTextBox" Width="240" runat="server" Enabled="False"></asp:dropdownlist></td>
</tr>
On noticing the attribute Enabled=False for both list boxes i spent hours trying to find the source file where this markup originates.
I found it in the /Admin/Lists folder. And the file to edit is listeditor.ascx
Change the Enabled=False atribute to Enabled=True
I made a backup of the listeditor.ascx file before making any changes 'Just in case!' a practice that i recomend.
Hope this helps
Dave.
2006-11-03 11:14 AM
Hi Dave,
That's great, thanks for taking the time to post a solution, I'm sure this will help a lot of people until the bug is fixed in 4.3.x
- Do you need a list of the UK regions? - I created a list for a project way back in DNN2.x - you may want to alter some of them, but it will give you a starting point if you need them.
2006-11-03 11:33 AM
I figured I would post a list here for anyone else needing to create a list of UK regions, there maybe others to add, but this is the list I managed to put together for a project.
UK Counties:
West Sussex
Surrey
Kent
East Sussex
Wiltshire
Oxfordshire
Hampshire
Buckinghamshire
Berkshire
Somerset
Gloucestershire
Dorset
Devonshire
Cornwall
Isle of Wight
Jersey
Scilly Isles
Guernsey
Suffolk
Norfolk
Hertfordshire
Essex
Cambridgeshire
Bedfordshire
Worcestershire
West Midlands
Warwickshire
Staffordshire
Nottinghamshire
Northamptonshire
Leicestershire
Herefordshire
Derbyshire
West Yorkshire
South Yorkshire
North Yorkshire
East Yorkshire
Tyne and Wear
Northumberland
Lincolnshire
County Durham
Cleveland
Isle of Man
Shropshire
Merseyside
Greater Manchester
Lancashire
Cumbria
Cheshire
Greater London
Ayrshire
Europe
None
Antrim
Ards
Armagh
Avon
Ballymena
Ballymoney
Banbridge
Belfast
Borders Region
Carrickfergus
Castlereagh
Central Region
Coleraine
Cookstown
Craigavon
Derry
Down
Dumfries & Galloway Region
Dungannon
Durham
Dyfed
Fermanagh
Fife Region
Grampian Region
Gwent
Gwynedd
Hampshire
Highland Region
Larne
Limavady
Lisburn
Lothian Region
Magherafelt
Mid Glamorgan
Moyle
Newry and Mourne
Newtonabbey
North Down
Omagh
Orkney
Powys
Shetland (Zetland)
South Glamorgan
Strabane
Strathclyde Region
Tayside Region
West Glamorgan
Western Isles
Other
Scotland
Wales
Northern Ireland
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
I'm confused by this, too.
We are running DNN 6.x
