modify existing skin and use new skin under different name
Last Post 2006-11-02 10:37 AM by Lee Sykes. 1 Replies.
Don BowdenUser is Offline
2006-11-01 06:15 PM
How can I copy and modify an existing skin and upload and use that skin while still keeping the unmodified skin avialable to use?
I copied a skin, modified it and then zipped it up using a new skin name.  I then uploaded and installed the new skin, It worked and installed the new skin, but it installed under the portal folder in the same directory as the original skin folder, replacing the original skin files.  What am I doing wrong?  Thanks very much for your assistance!
Don
2006-11-02 10:37 AM
Hi Don,
If you rename the skin zip file that you upload as well, this should prevent you from replacing the original files.
DNN nav issue by imran shaikh
