My site is down
Last Post 2010-03-11 02:28 PM by proarch123. 8 Replies.
AnuPadduUser is Offline
2009-07-20 02:02 PM
Previously i have installed 5.0.1dnn version in server. I faced few problem like menu disappear when click the back button in browser. So i have upgrade the version 5.1. After some time i cant able to see my site. For testing purpose i put index.html file in the root directory. I can able to see that file. But not my site.
Can someone please tell me what to do now?
Anu
 <!--Session data-->[script removed]
Joseph CraigUser is Online
2009-07-20 02:06 PM
Are there any error messages?
2009-07-20 02:22 PM
Thanks a lot of ur reply.. No error message in DNN.
But i'm getting following error
Connection Interrupted
The connection to the server was reset while the page was loading.
The network link was interrupted while negotiating a connection. Please try again.
Anu
<!--Session data-->[script removed]<!--Session data-->[script removed]
2009-07-21 06:41 AM
Anybody help me please. Its really urgent. Why the connection is interrupted. The problem in IIS or any coding in Dnn.
Anu
proarch123User is Offline
2009-07-21 02:22 PM
Can you mention the steps you followed to upgrade your application to 5.1?
2009-07-21 02:34 PM
I will assume that putting an index.html file in your web directory still is served correctly.
Rename the index.html file to app_offline.htm.  When you browse to your site, that file should be served.  (I like to make a small change to the file, so that I know that it really is the app_offline file that is served.)
If app_offline is served, that means that ASP.NET is installed correctly on your web server.  If it isn't, then you need to look at the ASP.NET installation.
Let me know what happens when you do that.
2009-07-22 06:29 AM
Thanks for ur valuable suggestion. Renamed the file as app_offline.htm i can able to see the page in my site. Report the details to server maintenance team. Actually its IIS problem they check it and resolved the problem. Now my site is Up. Thanks a lot. I will ask them what changes they made in IIS and i will post it in forum it will help others.
Anu
2009-07-22 10:10 AM
Posted By proarch123 on 21 Jul 2009 8:22 AM
This should help:
How to Upgrade DotNetNuke (Auto Merge Method) (v4.6.2 to v5+)
Its the same method for upgrading for all versions of 4.6.2 and above.
The most important thing you can do is backup, backup, backup.
2010-03-11 02:28 PM
Thank you Lee Sykes
informative!!!
informative!!!
