Tutorial on customizing login page wanted
Last Post 2009-07-19 07:58 AM by Mulgurul. 3 Replies.
MulgurulUser is Offline
2009-07-14 08:56 AM
    I cant seem to find any tutorials on customizing the login page design.
    Do anyone know if its there somewhere and if not i suggest such an article!
    Peter Meldgaard
    2009-07-14 11:51 AM
    You can add the login module to a page, and customize the page. You can use CSS styles to customize the module's appearance.
    If you want to super customize, I'd recommend using Data Springs Dynamic Login module.
    Also, Joe Brinkman has a blog this week about creating a custom "authentication provider." You'll find his blog on the DotNetNuke site. This approach requires some programming skills.
    2009-07-14 05:26 PM
    The techniques outlined here will also help you to customize elements such as the login page styling:
    How to style and skin the search box in DotNetNuke
    The techniques in those tutorials would be what I would use for customizing the login page, as well as the info Joe has mentioned above.
    2009-07-19 07:58 AM
     Hi again, thanks for the great replies. I'll take a look on those tutorials.
    My main goal is to change the login button to a site specific image button instead of the plain dnn. Hope this can be achieved through the tutorials.
    Best regards
    Peter Meldgaard
