Programmer needed
Last Post 2009-07-11 05:05 PM by Hobes. 2 Replies.
HobesUser is Offline
2009-07-10 04:19 PM
<!--[if gte mso 9]> Normal 0 unctuationKerning/> false false false ontGrowAutofit/> MicrosoftInternetExplorer4 <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> <!--[if gte mso 10]>
Hi All,
I am looking for someone that has done some work with Datasprings modules, I have the source code and module for The realestate module, and I need to have some modifications made. Unfortunately I cannot afford the extended support the have datasprings do the modifications. If there is someone that might me good with these modules that would be interested in helping me out.. My Budget is $100.00
Sorry if I posted in the wrong forum.
Hobes
2009-07-11 02:26 AM
Good luck! It might help attract attention if you could describe the changes you need to have made. That way, interested programmers might be able to better understand if they can accomplish the changes with what seems to be a rather small budget.
2009-07-11 05:05 PM
Thanks for the reminder...Sorry I didnt add this in the beginning..
I just wanted to change a few text boxes to Dropdowns, I wanted to have Country dropdown available, as well as state province in the listing and search fields as well as a search by price range drop down with prepopulated list.
