How to Create Module :
Last Post 2009-07-10 04:40 AM by Germaine. 2 Replies.
hassangas2003User is Offline
2009-07-04 06:57 AM
this first my question in aforum,i'm abeginer in DNN,I have web user control already used to old project and now i need to add this web user control to  DNN 5,please all,how to added.
and plz how to Create new Module directly in DNN v.5???
this my try to do that:
1- New file and select DotNetNuke Dynamic Module.
2- Rename module(APP_CODE,DesktopModules)
I KNOW THIS SIMPLE TRY>>>>
PLAESE ALL HELP ME>
PLEASE STEP BY STEP
IAM WAITTING..............
thaunks,
hassan
Joseph CraigUser is Online
2009-07-04 12:10 PM
I'd recommend the book on DotNetNuke module development by Mitchel Sellers, and also adefwebserver.com. There is a module development guide there.
GermaineUser is Offline
2009-07-10 04:40 AM
Hi Hussan,
My understanding is that you already have a existing web page (with all the functions/codings), you want to copy this into DNN 5.1? Is that what you trying to say?
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
I'm confused by this, too.
We are running DNN 6.x
