Change Login Page
Last Post 2009-07-05 09:51 AM by Lee Sykes. 2 Replies.
FozzyUser is Offline
2009-07-04 02:14 AM
Hey guys it’s me again. Great work on session 46 keep up the great work! I want to be able to add modules to a couple panes on my admin pages and the login page. How can I make changes to those pages?
2009-07-04 01:08 PM
If you want to add modules to the login page, first create a page and then add the login module. Then add other modules. Configure the new page as the login page.
With Version 4 of DotNetNuke, it's difficult to modify admin pages. You can do that much more easily with Version 5.
2009-07-05 09:51 AM
To configure the new page as the login page go to admin menu / site settings
When you do this, make sure you test it beforehand that you can login with the page, and also make sure you select the correct page as some users accidentally select the wrong page and then can not log in.
