SWF Tutorial Conversion
Last Post 2011-12-20 02:14 PM by Joseph Craig. 5 Replies.
RayUser is Offline
2009-07-03 01:30 PM
    I have been trying to convert some of the older SWF tutorials to a format that I can load on my Zune or iPod. I tried several SWF conversion applications without success. When I perform the conversion, the only section that gets converted is the opening and not the body. So far, I tried about 6-7 applications all with the same outcome. Can you offer any suggestions?
    Ray
    chiconeyUser is Offline
    2009-07-07 02:18 AM
    you can convert swf to wmv format for your zune and convert swf to mp4 or h.264 for your ipod.
    there are many swf to video converters can do that, but maybe you really got a bad luck.
    you can just follow my choice, i use iwisoft swf to wmv converter which can convert swf to h.264 as well. good luck!
    kevin 8User is Offline
    2011-10-27 08:23 AM
    This FLV Encoder: http://www.swf2ipad.com/flv-encoder.html
    is a feature-rich video to Flash solution combined with Flash video encoder, video to flash swf converter, and even Flash video player maker. It can fast convert any video to Flash FLV and SWF, including AVI, MP4, 3GP, MPEG, WMV, etc, and even HD MOV, MKV, M2TS and MTS.
    Andy StephensonUser is Offline
    2011-11-11 10:55 AM
    Hi Ray, this is interesting...
    I am encoding all recent and future tutorials in h.264 to try to cater for the mobile market.
    The latest video series should work on your iPod (does it have wifi?).
    http://www.dnncreative.com/Home/Tut...NN-6x.aspx
    I'd be interested to know if it works ok for you and can you visit the video on wifi, wait until it has fully downloaded / buffered and then watch the video later without an internet connection?
    Cheers, also, let me know if you manage to convert the swf's and how the quality is.
    Andy
    Adward FalenUser is Offline
    2011-12-20 07:51 AM
    Here is a step-by-step tutorial about how to convert SWF to WMV on Mac.
    Hope it can help.
    2011-12-20 02:14 PM
    Thanks.
