I have a problem with Mozilla
Last Post 2009-07-03 08:13 AM by Lee Sykes. 1 Replies.
ebendelasUser is Offline
2009-07-02 03:34 PM
I have this problem. In a container (with name Banner 1) have this code: <%@ Control language="vb" CodeBehind="~/admin/Containers/container.vb" AutoEventWireup="false" Explicit="True" Inherits="DotNetNuke.UI.Containers.Container" %> <%@ Register TagPrefix="dnn" TagName="ACTIONS" Src="~/Admin/Containers/Actions.ascx" %> <td class="banner_text" id="ContentPane" runat="server" align="left" valign="top"/>
<dnn:ACTIONS runat="server" id="dnnACTIONS" ProviderName="DNNMenuNavigationProvider" ExpandDepth="1" PopulateNodesFromClient="True" />
The container.css has this code: .containerbanner { border:1px solid #F60; background-color:#FFF; padding:2px 2px 1px 2px; margin-bottom:10px; width:100%; float:inherit } .banner_text .Normal{ font-family:Arial, Helvetica, sans-serif; font-size:12px; color:#3399CC; float:left; } .banner_text .Normal a{ color:#3399CC; text-decoration:underline; float:left; } .banner_text .Normal a:hover{ text-decoration:none; } My problem is with the Mozilla. In IE it is all OK. But the Mozilla don’t have the img in central of container. Thanks
2009-07-03 08:13 AM
I can't see any css code in here for styling images in your classes, perhaps you need to look at styling the img tag within the .banner_text class,
