problem while creating new module
Last Post 2009-07-11 03:54 PM by Joseph Craig. 1 Replies.
nagachaitu.netUser is Offline
2009-07-02 07:17 AM
 I develpoed a seperate module for payment gatway,if the payment is processed...it is redirect to the other page where we
get the transaction details .. now instead of redirecting it to the page created in the new module, if i redirect the page to
the tab created in the dnn site...  how do i retrive the transaction details...  what is module i can go for this,..
just help me... it's very urgent....
i am implementing DIBS Payment Gateway... which doesnot support query string...
2009-07-11 03:54 PM
I need some more details.
DNN nav issue by imran shaikh
