DotNetNuke ASCX Skinning for Professional Skinners - issue 46
Last Post 2009-10-18 11:26 PM by Lee Sykes. 31 Replies.
Page 1 of 212 > >>
2009-06-29 07:40 PM
    Add any comments or questions regarding the DotNetNuke ASCX Skinning for Professional Skinners tutorial from issue 46
    thanhdienUser is Offline
    2009-07-01 04:09 AM
    please give me tutorials dotnetnuke
    2009-07-01 07:32 AM
    To access the tutorials you need to subscribe to the website, you can do this here:
    http://www.dnncreative.com/Subscrib...fault.aspx
    and this will then give you access to all of the videos on the website, thanks,
    LeeWebDevUser is Offline
    2009-07-01 08:43 PM
    Hi Lee, I just watched my first video tutorial (issue #46) and all I can say is WOW...what a great resource! Your style of teaching is perfect for me...not too fast and not too assuming. Great job! I can't wait to watch the previous videos.
    One question about this tutorial: I have Visual Studio 2008 Standard Edition and would have thought that the pop-up elements would have appeared like they do with VWD Express, but they don't. Is there something that needs to be turned on in VS to see the elements available to me when editing the ASCX files?
    Thanks again for this hard work you're doing.
    David
    2009-07-01 09:41 PM
    hello,
    Glad to hear you have found the tutorials useful, that's always good to hear!
    I would also assume that visual studio 2008 Standard Edition would do this instantly, but I do not have a copy to test. Did you open the website at the root of your DotNetNuke installation files? - if you open it for example in your skins folder it will not work.
    Shidler College of BusinessUser is Offline
    2009-07-08 07:53 AM
    Just wanted to drop a line to mention how excited I was to see this month's lead topic was on skinning with the ASCX method! I was just thinking it was about time for me to get into it as well. So anyhow I devoured those vids and am hungry for more. Will there perhaps be a continuation on the subject?
    - Loren in Honolulu
    2009-07-08 02:15 PM
    David GoodUser is Offline
    2009-07-10 12:53 AM
    When building the skin, you register the skinobject controls once for each time you use the skinobject in your ascx file e.g. in the tutorial you register the dnn menu twice for two instances of the menu. Is it possible to just register the menu once and then use it twice by changing giving the second instance a different id only e.g. dnnMenu1, dnnMenu2.
    2009-07-10 01:19 AM
    Yes, I have seen almost all of those videos actually. I originally signed up to DNN Creative to learn more about skinning in particular, and your videos have been an invaluable resource! I believe these were the first ones to specifically focus on ASXC skinning though, no?
    I suppose anything that falls under the category of "advanced skinning techniques" would be of interest to me. Just off the top of my head I might like to learn more about:
    The DNNMenuNavigationProvider
    I get the feeling I don't know the full capabilities of the default DNNMenuNavigationProvider. I know you like the HouseMenu (I've used it on a couple projects too -- it is nice), but nonetheless would be interested in doing some fancy things with the default menu. Isn't it a bit better than the SolPartMenu was? And maybe it can do some things the HouseMenu can't do?
    jQuery
    Maybe something about using jQuery to make photo slideshows or tabbed content within the text/html module?
    Well anyway I'm what you'd call a 'satisfied' customer. I really do appreciate all your hard work and look forward to each issue. Thanks.
    2009-07-10 04:40 PM
    Posted By Libertytec on 09 Jul 2009 7:53 PM
    I've just checked that out and yes you can as long as you have a different id.
    2009-07-10 04:42 PM
    Posted By shidlercollegeofbusiness on 09 Jul 2009 8:19 PM
    I'm looking at the NavMenu for issue 47 ;-)
    CrizTizzyUser is Offline
    2009-07-13 04:45 PM
    I thank you BIG TIME for the PDF version, I think I would have lost the will to learn about aspx if it wasn't for that option.
    It wasn't a good surprise to see that I had to download all the videos in one file (over 334 MB Flash format zipped) and encounter 84 MBs of files for Video 1. Downloading the WMF files is smaller but still over 115MB. That seems to be about 3 times the file size of earlier files. If it's at all possible, please go back to one video per tutorial and reduce the file size.
    2009-07-13 05:51 PM
    Its not possible to reduce the file size, but I would suggest you download wmvs because they are much smaller. I placed all of the videos into 1 zip file as other people have requested that they find it frustrating extracting all of the zips. Why don't you like downloading larger files I thought this would save you time?
     I guess I could go back to the single download per video, but I would welcome anyone else's thoughts first, thanks,
    ORBIDUser is Offline
    2009-07-27 03:56 PM
    i use the navmenu on top and on the left side. I found how to link the topmenu with the leftmenu as child.
    But how can i force the menu on the left to show all menu items.
    current situation
    On top
                             MenuItem1  MenuItem2 MenuItem3  MenuItem4
    menusubitem1a - subsub1 (Expand if you the cursor moves over menusubitem1a)
                              - subsub2
    menusubitem1b
    menusubitem1c
    menusubitem1d
    situation i want
    On top
    menusubitem1a
        - subsub1
        - subsub2
    menusubitem1b
        - subsub1
        - subsub2
        - subsub3
        - subsub4
    menusubitem1c
        - subsub1
    menusubitem1d
    2009-07-31 10:26 AM
    hello try this:
    <!--[if gte mso 9]> Normal 0 unctuationKerning/> false false false oNotPromoteQF/> EN-GB X-NONE X-NONE ontGrowAutofit/> ontVertAlignCellWithSp/> ontBreakConstrainedForcedTables/> ontVertAlignInTxbx/> <!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:0; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:-1610611985 1107304683 0 0 415 0;} @font-face {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1593833729 1073750107 16 0 415 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; mso-bidi-font-size:12.0pt; font-family:"Verdana","sans-serif"; mso-fareast-font-family:"Times New Roman"; mso-bidi-font-family:"Times New Roman";} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; font-size:10.0pt; mso-ansi-font-size:10.0pt; mso-bidi-font-size:10.0pt; mso-ascii-font-family:Verdana; mso-hansi-font-family:Verdana; mso-ansi-language:EN-US; mso-fareast-language:EN-US;} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 72.0pt 72.0pt 72.0pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> <!--[if gte mso 10]> ForceDownLevel="True"
    2009-08-03 07:06 AM
    That doesn't work with DNNMenuNavigatorProvider.
    See: DNN Navigation controls - page 19
    2009-08-03 07:22 AM
    Did you try the setting out? It works in my menu, there are a couple of attributes in that doc which appear to be not correctly documented.
    2009-08-03 07:31 AM
    i already tried it. But it doesn't do anything.
    This is my head menu:
                    <dnn:nav runat="server" id="NAV_Top" providername="DNNMenuNavigationProvider" indicatechildren="false">
                        ControlOrientation="Horizontal" CSSControl="mainMenu" CSSNodeSelectedRoot="MenuRootItemSelected"
                        ExpandDepth="0" StartTabId="-1" PopulateNodesFromClient="false" ForceDownLevel="false"
                        ForceCrawlerDisplay="false" />
    and this is the child menu:
                    <dnn:nav runat="server" id="NAV_Left" providername="DNNMenuNavigationProvider" indicatechildren="false">
                        ControlOrientation="Vertical" CSSNodeSelectedSub="MenuSubItemSelected" CSSControl="childMenu"
                        Level="Child" ForceCrawlerDisplay="true" PopulateNodesFromClient="true">
    if i click on a childmenu my menu disappear (span is not visible i think)
    see: www.placidus.be
    2009-08-03 08:16 AM
    Any idea why the child menu disappear when i click on one item (from the submenu)?
    2009-08-03 04:03 PM
    You may want to check out this tutorial which is in the next issue 47:
    DotNetNuke NAV Menu
    In particular Videos 10 and 11 which deal with 2 menus on a page.
    Page 1 of 212 > >>
    RE: Deploying dnn by Sameer
    Just sent it.
