Reduce the database size
Last Post 2009-07-01 10:08 PM by Lee Sykes. 2 Replies.
AnuPadduUser is Offline
2009-06-29 02:40 PM
I need to delete Event log details in database. Whether i can go and delete it straightly in the db. If it so it wont affect any other references? coz i need to reduce my database size. Any other ideas plzzz
AnuPaddu
<!--Session data-->[script removed]
2009-06-29 07:44 PM
Use the SQL page under host, enter "Truncate Table EventLog," and then click Execute.
I also refer you to Mitchel Sellers blog (mitchelsellers.com) for discussion of this and also a module that automates some maintenance tasks.
2009-07-01 10:08 PM
you can set your scheduler to automatically delete old event logs. also in the event logs, you can set how many event logs should be kept, some of them are set to * unlimited, and you may want to change this to just 20 log entries.
We cover this in detail here:
Site logs, Event logs and Scheduler
DNN nav issue by imran shaikh
