DNN Search for CataLooK
Last Post 2009-07-01 09:53 PM by Lee Sykes. 4 Replies.
taetsuUser is Offline
2009-06-28 11:38 AM
Hi, I'm looking for guidance/tutorial on how to implement the ISearchable for catalook module, to allow DNN search for my listed products titles. I'd been google around and read a few examples and still come to no clues on how to start. please help me with this.. Thanks.
2009-06-28 02:58 PM
ISearchable is an interface that is built into the module. It is not something that you can add.
2009-06-29 04:04 AM
is that means there is no way to get DNN search engine to index my catalook contents?
i've purchased catalook with source, i thought i can just implement ISearchable on the catalook class?
2009-06-29 07:49 PM
I would ask the folks who create Catalook about this.
2009-07-01 09:53 PM
You could try a module such as this one for your search rather than default DNN core search:
Xepient Solutions Open-SearchEngine v2.0 Review for DotNetNuke
DNN nav issue by imran shaikh
