Module installation problem
Last Post 2009-06-29 04:38 PM by Muledi. 2 Replies.
AnuPadduUser is Offline
2009-06-25 05:59 AM
Im facing one issue in module installation. The modules get install with out error but the problem is i cant able to see the module in the control panel when i go to desktop modules (Dnn Files) installed module files and folders are there.. can u plzz tell me the solution. I cant step forward due to this.. Urgent plzz
AnuPaddu
2009-06-29 02:35 PM
no ideas.....<!--Session data-->[script removed]
MulediUser is Offline
2009-06-29 04:38 PM
what's the module name? is it one you have written yourself?
DNN nav issue by imran shaikh
