FCKEditor not displaying text in Rich Text Editor
Last Post 2009-07-01 08:54 AM by Lee Sykes. 5 Replies.
Matt MerchantUser is Offline
2009-06-25 03:36 AM
Having frustrating time with the FCKEditor not displaying text properly when in Rich Text Editor mode.
When switching to either Basic Text Box or Source view, I can see the raw HTML.  In the rich text mode, if text is enclosed in < p > ... < / p > tags it does not display, or displays in microscopic size. Any other HTML tag renders properly.
So far I have tried....
Setting the "HTMLEncoding Output" option to Yes (from Default)
Setting the "Reverse HTML encode output" option to Yes (from Default)
Setting the "CSS Generator Mode" to Dynamic (from Static)
It does not appear to make a difference which skin I use - results are the same...
Have tried to edit from different computers / networks - results are same...
One additional clue - the FCKEditor works fine on my local development server. It does not work on my hosted production server (Verio). Verio does not allow for dynamic writing to web.config - has to be done manually - not sure if that is making a difference or not.
Any thoughts?
Thanks !
Matt
2009-06-26 04:46 PM
Anyone else seeing this problem with the FCKEditor?
2009-06-26 05:32 PM
One more symptom...when I change the FCK Editor preferences, they are not saved. I have made sure to check the "Portal" radio button prior to Applying the changes...
Any thoughts?
mkkUser is Offline
2009-06-26 08:53 PM
I am also facing problem with FCKeditor i need to change the default font color in FCKeditor,
any one has some idea on how to change the default color, post here
mkkUser is Offline
2009-06-27 12:35 AM
i did it finally, to many changes in FCKeditor text area, goto
\Providers\HtmlEditorProviders\Fck\FCKeditor\editor\css\fck_editorarea.css and make changes there(ex in body for background...) and important thing is clear the cache in the browser and refresh r run it again
2009-07-01 08:54 AM
hello,
If the settings are not being saved for the FCK editor, this may mean that the correct read and write permissions on your DotNetNuke installation files are not set. Contact your hosting provider and ask them to reset the correct read and write permissions for running DotNetNuke (occasionally you may find that you need to reset permissions if you have made changes to the files on your website)
Regarding the display of the text - try this as a test, add some text to a page and then change the skin of the page to the default minimal extropy skin and see if the text displays correctly.
It sounds as though there is some skin CSS code resizing anything inside p tags
Problem After Attaching/Detaching Database.mdf by Prakasam Srinivasan
I successfully installed DNN 6 on my local machine using IIS 7.5. Its working good. When I attach to
RE: Module Security permissions by Bhushan Gholap
Thanks for the reply!!! I would definitely contact sales engineer team of DNN.
RE: There's a tutorial for this somewhere by Eric W
The error I got was the Connection Error(s): Index #: 0 Source: .Net SqlClient Data Provider
RE: DNN 6 Modules Not Showing by Joseph Craig
Where can I see this? If you'd like to send me some login credentials so that I can look, use the c
RE: DNN 6 Modules Not Showing by Mike DeBaise
No, modules are set to all viewers/users. Just cant figure this out, it really doesnt make any sense
RE: Searching in DNN by Alex Ritter
Will do Joseph. I'll let you know my findings.
RE: DNN Blog module syndication by Aggiedan97
The reason I bring it up - Lee had originally provided a tutorial regarding podcast submission to iT
RE: installing DNN locally - problems with relative path by Joseph Craig
Recently I discovered this very useful blog post: http://www.dotnetnuke.com/Resources/Blogs/EntryId
installing DNN locally - problems with relative path by Prakasam Srinivasan
Instead of making tests on my live site, I recently seen various tutorials concerning installing DNN
RE: Moved site to subdomain, now no links work by Joseph Craig
PortalAlias is a table in the DotNetNuke database. Normally you would adjust this on the Site Set
Did you also check the module permissions? Are the modules permissions such that only logged in use
RE: Add to the menu with a custom module by Joseph Craig
I can't tell you how to do this, but ... I'd think you could start with a version of the Mega menu i
RE: Where is the Manage Profile default Properties required error message found? by Joseph Craig
You'll find it in one of those resource files you can get at with the Language Editor. I'm not sure
RE: Facebook Like Button by Joseph Craig
You can get the code you need from Facebook and then you can paste it into an HTML module in HTML mo
RE: Module Security permissions by Joseph Craig
Just a thought -- as you are evaluating the Professional version of DotNetNuke, you might want to as
The module permissions that you mention are for the module: Edit the module's settings, Delete the
When you login are you a member of the Administrators security role? I don't believe that you can d
Hello all. I created a skin for DNN 6 and noticed that only while I am logged in can I see the modul
RE: URL login bypass by Joseph Craig
If you want the private page to be protected, you are going to have to have some way of "logging in.
RE: DNN Blog module syndication by Joseph Craig
Sorry. I'm not really familiar with feedburner and I haven't had a chance to research this. While
