Problem with top pane
Last Post 2009-06-26 11:34 AM by Lee Sykes. 1 Replies.
dnnkUser is Offline
2009-06-23 05:56 PM
I have installed a module in top pane but I am unable  to insert the module where i wish.
Even the  control panel has left,right,center but unable to place at correct point.
How to solve this?
Thanks in advance
2009-06-26 11:34 AM
go to the module that you placed in the top pane, and go to its settings menu, in there you can select which pane to move the module to.
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
