meta tag
Last Post 2009-06-26 12:30 PM by Lee Sykes. 3 Replies.
claudeUser is Offline
2009-06-23 04:07 PM
Where can i find my  home page HTML , I like to add some meta tag?
Claude
Joseph CraigUser is Online
2009-06-24 06:54 PM
You can add meta tags using the Page Settings for a particular page.
If you want to add meta tags to every page, you'll want to modify Default.aspx, but it will insert the meta tag on every portal. It will also disappear if you upgrade, so remember to keep a copy.
I can't recall if you can add meta tags in skin files, so you'll want to check on those.
2009-06-25 02:13 AM
Thanks Joe ,
I want to put a meta tag from google to be verified for the search engine
2009-06-26 12:30 PM
quickest way for the verification code from Google is to go to your home page / page settings / advanced settings
and page header tags
in there paste the code from Google
scroll to the bottom, click update
Problem After Attaching/Detaching Database.mdf by Prakasam Srinivasan
I successfully installed DNN 6 on my local machine using IIS 7.5. Its working good. When I attach to
RE: Module Security permissions by Bhushan Gholap
Thanks for the reply!!! I would definitely contact sales engineer team of DNN.
RE: There's a tutorial for this somewhere by Eric W
The error I got was the Connection Error(s): Index #: 0 Source: .Net SqlClient Data Provider
RE: DNN 6 Modules Not Showing by Joseph Craig
Where can I see this? If you'd like to send me some login credentials so that I can look, use the c
RE: DNN 6 Modules Not Showing by Mike DeBaise
No, modules are set to all viewers/users. Just cant figure this out, it really doesnt make any sense
RE: Searching in DNN by Alex Ritter
Will do Joseph. I'll let you know my findings.
RE: DNN Blog module syndication by Aggiedan97
The reason I bring it up - Lee had originally provided a tutorial regarding podcast submission to iT
RE: installing DNN locally - problems with relative path by Joseph Craig
Recently I discovered this very useful blog post: http://www.dotnetnuke.com/Resources/Blogs/EntryId
installing DNN locally - problems with relative path by Prakasam Srinivasan
Instead of making tests on my live site, I recently seen various tutorials concerning installing DNN
RE: Moved site to subdomain, now no links work by Joseph Craig
PortalAlias is a table in the DotNetNuke database. Normally you would adjust this on the Site Set
Did you also check the module permissions? Are the modules permissions such that only logged in use
RE: Add to the menu with a custom module by Joseph Craig
I can't tell you how to do this, but ... I'd think you could start with a version of the Mega menu i
RE: Where is the Manage Profile default Properties required error message found? by Joseph Craig
You'll find it in one of those resource files you can get at with the Language Editor. I'm not sure
RE: Facebook Like Button by Joseph Craig
You can get the code you need from Facebook and then you can paste it into an HTML module in HTML mo
RE: Module Security permissions by Joseph Craig
Just a thought -- as you are evaluating the Professional version of DotNetNuke, you might want to as
The module permissions that you mention are for the module: Edit the module's settings, Delete the
When you login are you a member of the Administrators security role? I don't believe that you can d
Hello all. I created a skin for DNN 6 and noticed that only while I am logged in can I see the modul
RE: URL login bypass by Joseph Craig
If you want the private page to be protected, you are going to have to have some way of "logging in.
RE: DNN Blog module syndication by Joseph Craig
Sorry. I'm not really familiar with feedburner and I haven't had a chance to research this. While
