Html editor
Last Post 2009-06-26 12:19 PM by Lee Sykes. 1 Replies.
GDGUser is Offline
2009-06-22 11:05 PM
Hello. Iam having one problem with MMLink. This problem is HTML editor doesn´t justifate the text in the website but in the editor appear justifikate.
What can I do to solve this problem.
Thank you very much.
2009-06-26 12:19 PM
Try going to module settings and setting the alignment.
Or if that doesn't work, see if you can look at the module.CSS file and see if any text alignment is specified in the CSS.
DNN nav issue by imran shaikh
