first time user login
Last Post 2009-06-23 05:33 PM by mkk. 6 Replies.
mkkUser is Offline
2009-06-19 06:10 PM
Hi i need some help for the following, When the user registered and when he login for the first time(just for the first time) he should redirect to different page and for 2nd ... nth time he should able to see normal home page. Thanks
mkkUser is Offline
2009-06-19 08:23 PM
give me some idea if someone knows about this
thanks
2009-06-20 01:22 AM
You might be able to do this with Data Springs' Dynamic Login module.
You can download the user manual at datasprings.com, read it, and see if you can use it.
mkkUser is Offline
2009-06-20 09:25 PM
Thanks for your reply craig, i will try that for sure
mkkUser is Offline
2009-06-22 06:34 PM
hi craig we are using custom login module, so now my proble is how to pass userid to stored procedure: attaching related code:
1622341886171.txt
2009-06-23 12:52 PM
I suggest that you take a look at adefwebserver for lots of help with module development.  You can also look at the new book by Mitchel Sellers.
mkkUser is Offline
2009-06-23 05:33 PM
k sure i will have a look, thanks craig
DNN nav issue by imran shaikh
