New Page Config
Last Post 2009-06-24 02:39 PM by Lee Sykes. 1 Replies.
Rob TrumanUser is Offline
2009-06-17 08:23 PM
I am using 4.9.1 and I have a wordpress blog. I tried using the link for the page in advanced settings put that dosent allow for opening up the link in a new window. I dont really want the users leaving the site but want them to be able to go to my blog. Im looking for suggestions on this. I may resort to the RSS Reader. Thanks
2009-06-24 02:39 PM
Other options could be to add the link to your blog directly within your skin code, from there you will be able to specify open in new window.
DNN nav issue by imran shaikh
