How to install core modules in DotNetNuke 5
Last Post 2009-08-31 04:24 PM by Nick Duffill. 1 Replies.
2009-06-04 02:05 PM
hello,
The location for installing the core modules in DotNetNuke 5 has changed and it may take a while to find them, here's where to go:
Go to the host menu / extensions
Scroll to the bottom of the page
Click on 'batch install extensions'
This will give you the list of available core modules to install, including the media module.
Nick DuffillUser is Offline
2009-08-31 04:24 PM
As a laughably green newbie, I lost some time before discovering that I was in "View" mode and not "Edit" mode. You don't get the menu or links in View mode :-)
Nick
DNN nav issue by imran shaikh
