problem with calendar title
Last Post 2009-06-24 06:35 PM by mkk. 5 Replies.
mkkUser is Offline
2009-05-29 06:39 PM
i am not able to change calendar title properties my code <asp:Calendar ID="Calendar2" runat="server" onselectionchanged="Calendar2_SelectionChanged" Visible="False" BackColor="White" BorderColor="Black" BorderStyle="Solid" Font-Names="Verdana" Font-Size="9pt" ForeColor="Black" Height="200px" Width="230px" CellSpacing="1" NextPrevFormat="ShortMonth" > in the title style eventhough the forcolor is white(any other color) its displaying black by default, i am not able to change that can any one solve this issue Thanks
mkkUser is Offline
2009-05-29 06:54 PM
<asp:Calendar ID="Calendar2" runat="server" CssClass="calendar" titlestyle-cssclass="Title" onselectionchanged="Calendar2_SelectionChanged" Visible="False" BackColor="White" BorderColor="Black" BorderStyle="Solid" Font-Names="Verdana" Font-Size="9pt" ForeColor="Black" Height="200px" Width="230px" CellSpacing="1" NextPrevFormat="ShortMonth" >
mkkUser is Offline
2009-05-29 06:55 PM
Height="8pt" />
ForeColor="White" Wrap="True" BorderStyle="Solid" Height="12pt"
CssClass="CalTitle" />
this is my code
2009-05-30 02:49 PM
Is this in a custom module?
2009-06-04 02:09 PM
for troubleshooting colours, code and CSS classes, I would recommend you use the web developers toolbar for Firefox. I have created a tutorial on how to use this here:
- a tip: if you wish to post code in the forum, attach any code in a zip file to your forum post, thanks,
mkkUser is Offline
2009-06-24 06:35 PM
Ya craig it is in a custom module, i fixed it bu adding a css class to it,
thanks lee i will go through the tutorial.
DNN nav issue by imran shaikh
