problem with 4.9.4
Last Post 2009-05-28 07:16 PM by Joseph Craig. 1 Replies.
sharadUser is Offline
2009-05-28 01:25 PM
We have successfully uploaded dotnetnuke skin for DNN 4.9.1  but when uploadin the same skin for DNN 4.9.4 it is giving error.
Is there any issue with 4.9.4 related to above?
Regards,
Bhawana
Joseph CraigUser is Online
2009-05-28 07:16 PM
There should not be an error. What is the error?
RE: DNN 6.2 by Joseph Craig
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
