Twitter Feed
Last Post 2009-11-02 01:42 AM by sun wangji. 4 Replies.
JamesMHUser is Offline
2009-05-06 03:43 PM
I am trying to incorporate a twitter feed into my DNN site.  I've tried Tiny Twitter but am not fully able to make it look how I want it to.  Can anyone else recommend any other modules?  Many thanks  James
2009-05-07 01:54 AM
Some possible solutions are:
http://www.codemypantsoff.com/About...fault.aspx
http://www.codeplex.com/Monitter4DNN
http://twitterdnn.codeplex.com/
Also, look at DayofDNN.com for an example. You might want to check with them to see what they are using.
Gifford WatkinsUser is Offline
2009-05-07 05:38 AM
I can help you out. Here is a twitter feed installed using DNN core module: text/HTML
http://iqportals.net/PortalModules/...fault.aspx
Go here to get your code:
http://twitter.com/widgets (look for "other")
Paste the code into the "source" text/HTML module... and Update.
(you may want to manipulate the width in the source as well)
Gifford
giffie.ca
Gifford Watkins, BSc, MA
Founder and CEO, Webfitters
2009-05-07 07:24 PM
Thanks for your contribution!
sun wangjiUser is Offline
2009-11-02 01:42 AM
Also you can check out another nice solution for twitter feed.
http://www.sunblognuke.net/Blog/ent...-Blog.aspx
Thanks a lot.
