Problem when installing 4.9.3
Last Post 2009-05-06 03:13 PM by Lee Sykes. 1 Replies.
SakthiUser is Offline
2009-05-06 01:11 PM
I am trying to install DNN Version 4.9.3. During installation i did the following,
 * Chosen custom installtion
 * I created new database and assigned it
after all the steps it shows installation completed, it is opening portal home page also...
but when i click on register / login link it shows "The resource cannot be found. Description: HTTP 404. The resource you are looking for (or one of its dependencies) could have been removed, had its name changed, or is temporarily unavailable.  Please review the following URL and make sure that it is spelled correctly.
Requested URL: /Home/tabid/38/ctl/Register/Default.aspx "
Can you please anyone suggest what is the problem in installation.
Thanks in advance!
2009-05-06 03:13 PM
Is this on a live site? Did you FTP all of the files to the live site? If so, some files maybe missing, try FTPing up the files again (EXCEPT the web.config) then make sure the permissions are reset on the files + folders for running DNN (Contact your hosting provider and ask them to do that for you)
DNN nav issue by imran shaikh
