hiding login link
Last Post 2010-03-25 03:55 PM by Joseph Craig. 44 Replies.
Page 1 of 3123 > >>
freedom22User is Offline
2009-01-31 12:12 PM
    I would like to build a dnn site where anonymous users do NOT see a register/login link, but administrators can login and edit the site by going to a separate page (e.g., www.sitename.com/admin) to login.
    Is this possible with DNN?
    Mark
    2009-01-31 03:30 PM
    Yes.
    Set your site to have no registrations (on the Admin, Site Settings page).
    The login page will be available at www.sitename.com/login.aspx.
    2009-01-31 03:37 PM
    Hi Joe,
    Thanks for your comment. Doesn't setting no registrations only remove the 'Register' link, but not the 'login' link? I(I tried setting up a site with "no registrations" and found the login link still visible.) Also, is www.sitename.com/login.aspx built in to the dotnetnuke framework? or do i have to set something up to get that? Would 'hiding' pages be of any use?
    Mark
    2009-01-31 05:11 PM
    Yes.  You are absolutely correct.  I should have had a cup this morning before answering.
    If you want to completely remove the login link, you can remove that skin object from within your skin file.  If you are working with an html version of the skin, you for "[LOGIN]" in the skin file, and just remove it.  If you want to remove the user skin object, that is "[USER]"
    The USER skin object displays "Register" (if permitted) to non-logged in users and the Display name to logged in users.
    The LOGIN skin object displays "Login" or "Logout"
    If you are working with .ascx skin files, then you'll want to look for and remove:
               < dnn:USER  runat="server" id="dnnUSER" / >
              < dnn:LOGIN runat="server" id="dnnLOGIN" / >
    Even if you don't want to display a login link to visitors, you might want to display the display name and a logout link once people have logged in.  John Mitchell (Snapsis.com) is the source of this code:
                < %  If DotNetNuke.Security.PortalSecurity.IsInRole("Registered Users")  Then% >
                        < div id="LoginUserContainer" >
                            < dnn:User cssclass="BannerLinks" runat="server" id="dnnUser" url="" / >
                            < dnn:Login runat="server" cssclass="BannerLinks" id="dnnLogin" / >
                        < /div >
                 < % End If % >
    (note that I've added some spaces to that the html tags won't be interpreted as such when this message is posted - remove them to use it.)
    If you add the conditional stuff around the USER and LOGIN skin objects, they will only be displayed to registered users.  YOu can change the role if you want to do this only for Administrators, for instance.
    Visit Snapsis' DotNetNuke support forums and you'll find a thread that has other uses for conditional code in skin files.
    I left out another way to login.  Either of these should work, provided that you haven't altered the default login page:
               http://mysite.com/login.aspx
               http://mysite.com/?ctl=login
    There are also logoff.aspx and ?ctl=logoff.
    2009-01-31 05:32 PM
    Joe,
    Thanks again for your prompt reply. I can do that for the skin. Thanks.
    Maybe the reason I am getting nowhere with the http://localhost/dnn_451_test/login.aspx to no avail.
    Does the 'login.aspx' trick only work for sites that have a real domain name? e.g., www.domainname.com/login.aspx?
    Mark
    2009-01-31 05:37 PM
    That trick should work.
    If you browse to your site as http://localhost/dnn_451_test, then appending /login.aspx to the url should work.
    You can also click your existing login link, and copy the URL that appears in your browser when you get to the login page.  You can simplify what is there, particularly removing the returnurl stuff.   But, copy that url and see if pasting it into the address box works.  Then continue to simplify it.
    2009-01-31 05:51 PM
    Hi Joe,
    It turns out that if I click the login link to get to the site, and copy that URL and append the login.aspx, I can get to the site just fine. (In fact I simplified somewhat by getting rid of the returnURL part and just used
    localhost/dnn_451_test/Home/tabID/37/ctl/Login/Default.aspx/login.aspx)
    However, if I just use 'localhost/dnn_451_test/login.aspx' I get a server error
    "Server Error in '/DNN_451_Test' Application
    The resource cannot be found.
    Description HTTP 404
    Requested URL: /dnn_451_test/login.aspx
    Maybe with locally hosted sites I have to use the larger version of the URL?
    Mark
    2009-01-31 06:08 PM
    I say go with what works!
    You might be able to removed tabID/37.  Keep pruning ...
    (Localhost isn't special, so I don't know why the even simpler version won't work.(
    2009-01-31 06:30 PM
    Well, I will just go with what works then. I can't get the short version to work on my machine. Thanks for your help, Joe.
    Mark
    Déclic Vidéo FXUser is Offline
    2009-09-25 08:44 PM
    I would like to know if it is possible to show the LOGIN name instead of the DISPLAY NAME at the top of the page where the login appears (once the user is logged in).
    Thanks in advance,
    DV FX
    2009-09-25 08:54 PM
    Perhaps the easiest way to do this would be to configure the Display Name to be the same as the Username.  You can do this on the User Settings page from User Accounts.
    Existing users will not be changed, but you can change it by running a SQL query to update DisplayName from Username.  Both are columns in the Users table.  So ... something like:
                UPDATE Users SET DisplayName = Username
    (Note that I didn't test this, so be sure to test it on a copy of your database before using it.  You can do this in the Host, SQL query window.)
                SELECT * FROM Users
    is the query you would use to check the results.
    2009-09-25 09:13 PM
    Hello Jcraig,
    Thanks for the answer, but that's not what I am trying to do. In fact, it is related to this topic, I am searching to display the LOGIN-NAME at the top of the screen, instead of Display name. By doing what you propose, it mean that all my database is modified, and when using "displayname" in other module (like comments from Ventrian), it will display Username instead of displayname, and that's not what I want...
    In my skin (*.ascx), I just want to alter the < dnn:USER runat="server" id="dnnUSER" / > to something which show the USERNAME instead of DISPLAY NAME... Possible ??
    Is there any token for this ???...
    DV FX
    2009-09-25 09:22 PM
    Create a content page where you want this to appear, and drop in a text/HTML module with token replacement enabled.  You have these tokens to work with:
    [User: DisplayName]
    User’s Display Name
    [User:Email]
    User’s Email Address
    [User:FirstName]
    User’s First Name
    [User:FullName]
    [deprecated]
    [User:LastName]
    User’s Last Name
    [User:Username]
    User’s Login User Name
    The TEXT skin object also supports token replacement (http://www.dotnetnuke.com/LinkClick...&mid=3944)
    You can use the TEXT and USER skin objects along with the conditional statemens shown in this thread to really customize things depending on whether the user is logged in or not, is a member of a specific role, etc.
    2009-12-30 12:38 PM
    Sorry for bothering you with this, but I was unable to achieve what you described...
    I would like to do the following: for all authenticated users, REPLACE the "login-name" which appears in my skin (all pages), with the "display-name"
    How could I achieve this ??
    I have seen that in my skin, there is the following:
    <dnn:USER runat="server" id="dnnUSER" CssClass="User_Link" />
    If I replace with dnnISPLAYNAME, it does not work.
    Can you guide me please ?
    DV FX
    2009-12-30 02:19 PM
    I'm a bit confused over your question.  If you are using the USER skin object in your skin, then it does display the DISPLAYNAME for authenticated users.
    2009-12-30 02:34 PM
    Sorry, I make an error. I would like to replace displayname by login-name....
    DV FX
    2009-12-30 02:47 PM
    OK, that makes sense!
    The USER skin object doesn't have an option to display anything other than the display name.  So, you will have to make a modification.
    If I were doing this, I would take the existing skin object and create an alternative skin object.  You will need to have a tiny bit of programming skill.  For information on creating skin objects, take at look here.
    Take the existing skin object, and create a skin object named USER-ALT.  For an absolute minimum, change the line that refers to objuserInfo.DisplayName to refer to objuserInfo.UserName.
    If you want to make if somewhat more useful, add an attribute that lets you choose between UserName and DisplayName.
    If this is beyond you ... let me know.  If I have some free time over the weekend, I might get motivated to do this ...
    2009-12-30 04:05 PM
    It was a short time to the weekend, and I shirked doing what I should be doing this morning ... so see the attached file, which is an installable skin object for DNN 5.x.
    This will install in DesktopModules/User-A and you can reference it in your skin files.  The attached index 1024.ascx file is a modification to the corresponding file in the Minimal Extropy skin.  You will see an additional register tag and a slight change to the tag that references the skin object.  I added a DisplayOption attribute.  If DisplayOption = "UserName" then the username is displayed.  Otherwise, the DisplayName will be shown just like the original skin object.
    1123052696871.zip
    112305271154.zip
    2010-01-02 04:29 PM
    Wow Joe,
    THANKS SO MUCH !! I am very happy to have it done, because I do not know how you done this ! I am a completely novice with such kind of things.
    Nevertheless, I still have some problems, I tried to use it, but I have the following error message:
    Could Not Load Skin: /Portals/0/Skins/s00/home.ascx Error: c:\hosting\xxxxxxxxxxxxxx\DesktopModules\User-A\User-A.ascx.vb(143): error BC30451: Name 'RegisterURL' is not declared.
    (I have replaced the path with xxxxx)
    Here is what I done:
    1/ Download the two files you sent me.
    2/ HOST > Module Definition > Install New Module and I used 1123052696871.zip
    Everything went well
    Resource Upload Logs
    StartJob Starting Installation
    StartJob Reading files
    Info Loading user-a.ascx
    Info File user-a.ascx read successfully
    Info Loading user-a.ascx.vb
    Info File user-a.ascx.vb read successfully
    Info Loading user-a.dnn
    Info File user-a.dnn read successfully
    EndJob Reading files done.
    StartJob Reading Installation Manifest file
    Info DNN file is in valid 2.0 SkinObject format.
    Info xml loaded.
    Info Loading files info
    Info Loading Modules info
    Info Loading Control info for '' module
    EndJob Manifest file finished successfully
    StartJob Begin Sql execution
    EndJob Finished Sql execution
    StartJob Creating files
    Info Created c:\hosting\xxxxxxxxxxxxxx\DesktopModules\USER-A\user-a.ascx
    Info Created c:\hosting\xxxxxxxxxxxxxx\DesktopModules\USER-A\user-a.ascx.vb
    Info Created c:\hosting\xxxxxxxxxxxxxx\DesktopModules\USER-A\user-a.dnn.config
    EndJob Files created
    Info Registering Controls
    EndJob Registering finished
    EndJob Installation successful.
    3/ Then I downloaded the file 112305271154.zip, I extracted it, and then I copy the code into my skin.
    When accessing the home page, I have the error message:
    I am running DNN 4.9.5
    What could I do ??
    Thanks so much,
    DV FX
    2010-01-02 04:51 PM
    Whoops. I did this for DotNetNuke 5.x. I think that this might not work with Version 4.x. I'll have to make a version for 4.x.
    Page 1 of 3123 > >>
    RE: Module Security permissions by Bhushan Gholap
    Thanks for the reply!!! I would definitely contact sales engineer team of DNN.
    RE: There's a tutorial for this somewhere by Eric W
    The error I got was the Connection Error(s): Index #: 0 Source: .Net SqlClient Data Provider
    RE: DNN 6 Modules Not Showing by Joseph Craig
    Where can I see this? If you'd like to send me some login credentials so that I can look, use the c
    RE: DNN 6 Modules Not Showing by Mike DeBaise
    No, modules are set to all viewers/users. Just cant figure this out, it really doesnt make any sense
    RE: Searching in DNN by Alex Ritter
    Will do Joseph. I'll let you know my findings.
    RE: DNN Blog module syndication by Aggiedan97
    The reason I bring it up - Lee had originally provided a tutorial regarding podcast submission to iT
    RE: installing DNN locally - problems with relative path by Joseph Craig
    Recently I discovered this very useful blog post: http://www.dotnetnuke.com/Resources/Blogs/EntryId
    installing DNN locally - problems with relative path by Prakasam Srinivasan
    Instead of making tests on my live site, I recently seen various tutorials concerning installing DNN
    RE: Moved site to subdomain, now no links work by Joseph Craig
    PortalAlias is a table in the DotNetNuke database. Normally you would adjust this on the Site Set
    Did you also check the module permissions? Are the modules permissions such that only logged in use
    RE: Add to the menu with a custom module by Joseph Craig
    I can't tell you how to do this, but ... I'd think you could start with a version of the Mega menu i
    RE: Where is the Manage Profile default Properties required error message found? by Joseph Craig
    You'll find it in one of those resource files you can get at with the Language Editor. I'm not sure
    RE: Facebook Like Button by Joseph Craig
    You can get the code you need from Facebook and then you can paste it into an HTML module in HTML mo
    RE: Module Security permissions by Joseph Craig
    Just a thought -- as you are evaluating the Professional version of DotNetNuke, you might want to as
    The module permissions that you mention are for the module: Edit the module's settings, Delete the
    When you login are you a member of the Administrators security role? I don't believe that you can d
    Hello all. I created a skin for DNN 6 and noticed that only while I am logged in can I see the modul
    RE: URL login bypass by Joseph Craig
    If you want the private page to be protected, you are going to have to have some way of "logging in.
    RE: DNN Blog module syndication by Joseph Craig
    Sorry. I'm not really familiar with feedburner and I haven't had a chance to research this. While
    Are you using a third party module to rewrite the URLs? If so, you may need an upgrade. Did you do
