Need video optimization tips
Last Post 2009-01-26 06:38 PM by Lee Sykes. 3 Replies.
SteveUser is Offline
2009-01-23 05:12 PM
I have several videos that I've posted on my dnn websites, and I would really like to optimize them as much as possible.  The .swf files (the only format my skin seems to support well) are upwards of 20mb and are taking a fair amount of load time.  The source files are .avi, are in the 220mb ballpark, and I'm converting to .swf using h.263, 780kbps, 352x288, 15fps; mp3, 64kbps as my conversion settings.  If there is a way to shrink the .avi files before I make the conversion without loosing too much fidelity, I'm fine with that.  Ultimately, I'd like to be able to make the videos larger and eliminate several artifacting issues, but so far to make that happen, I have to convert with setting that output files that are much to large.
Any hints or tips or references would be GREATLY appreciated.
Also, I've tried uploading the videos using the files tool and it times out.  I end up having to use ftp.  Anyone else experience this problem, or is it just me?
mgordonUser is Offline
2009-01-23 06:44 PM
I'll leave the video optimization to others, but I can tell you that the web.config file has a spot in there that configures how much, in file size, you can upload, and also provides a timeout setting.  Search for this in your web.config:
<!--  allow large file uploads -->
and change the maxRequestLength and requestLengthDiskThreshold.
I changed mine to look like this:
<!--[if gte mso 9]> Normal 0 unctuationKerning/> false false false oNotPromoteQF/> EN-US X-NONE X-NONE ontGrowAutofit/> ontVertAlignCellWithSp/> ontBreakConstrainedForcedTables/> ontVertAlignInTxbx/> MicrosoftInternetExplorer4 <!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:0; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:-1610611985 1107304683 0 0 159 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman";} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; font-size:10.0pt; mso-ansi-font-size:10.0pt; mso-bidi-font-size:10.0pt;} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.0in 1.0in 1.0in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> <!--[if gte mso 10]> (After Less Than Symbol)
httpRuntime useFullyQualifiedRedirectUrl="true" maxRequestLength="20480" requestLengthDiskThreshold="20480" executionTimeout="1200" /(Place Greater Than Symbol Here)
Notice the Execution Timeout.  This gives it time for the large file uploads.
Hope that helps.
Mark
Mark Gordon
Webmonkey
2009-01-23 06:45 PM
Search for "allow large file uploads" in web.config. Sorry, the Less Than Symbol and Greater than symbols got hidden in the forum.
Mark Gordon
Webmonkey
2009-01-26 06:38 PM
Video compression is a hard one to provide tips on as it depends on many factors. The one tip I can give is that I start with as high quality an AVI and audio as possible and from that I export it as a swf / flv / wmv / mov etc.
It's the settings for the actual export that count rather than compressing the initial AVI before doing the export. - at least in my experience anyway, others may have other opinions.
Finding the optimum settings can literally take days of exporting and analysing the results, thanks,
DNN 6.2 by Sameer
RE: Deploying dnn by Sameer
Thanks a lot so kind of you
I'm confused by this, too.
We are running DNN 6.x
