DotNetNuke.Modules.Help.DataProvider threw an exception
Last Post 2009-01-14 01:49 PM by elbayad. 3 Replies.
dnnmqUser is Offline
2008-10-27 09:04 PM
I just installed the Help 03.00.02 module into our DNN Version 4.8.3 site.
After adding the Help module to a page, we get this error:
Error: Help is currently unavailable.
DotNetNuke.Services.Exceptions.ModuleLoadException: The type initializer for 'DotNetNuke.Modules.Help.DataProvider' threw an exception. ---> System.TypeInitializationException: The type initializer for 'DotNetNuke.Modules.Help.DataProvider' threw an exception. ---> System.ArgumentNullException: Value cannot be null. Parameter name: type at System.Activator.CreateInstance(Type type, Boolean nonPublic) at DotNetNuke.Framework.Reflection.CreateObject(String ObjectProviderType, String ObjectProviderName, String ObjectNamespace, String ObjectAssemblyName, Boolean UseCache) at DotNetNuke.Framework.Reflection.CreateObject(String ObjectProviderType, String ObjectNamespace, String ObjectAssemblyName) at DotNetNuke.Modules.Help.DataProvider.CreateProvider() at DotNetNuke.Modules.Help.DataProvider..cctor() --- End of inner exception stack trace --- at DotNetNuke.Modules.Help.DataProvider.Instance() at DotNetNuke.Modules.Help.CategoryController.GetCategoryModules(Int32 TabID) at DotNetNuke.Modules.Help.Help.Page_Load(Object sender, EventArgs e) --- End of inner exception stack trace ---
2008-10-27 11:24 PM
I found a reply by Philip Beadle in www.dotnetnuke.com from 7/3/2007 to look in the bin folder and delete DotNetNuke.modules.Help.SqlDataprovider.dll file if it's there there. After I deleted the dll, the error went away.
2008-10-28 05:18 PM
Thanks for the tip
elbayadUser is Offline
2009-01-14 01:49 PM
hi i've the same error with the media module. i deleted the DotnetNuke.Modules.Media.SqlDataProviders.dll and nothing happend.
thanks a lot for help, because, even faq and forum modules display the same error.
