Bookmarks
Last Post 2008-10-10 03:26 PM by Lee Sykes. 1 Replies.
Régis MATHONUser is Offline
2008-10-04 05:49 PM
Do you a solution to input data in a UDT table by javascript?
I want to build a table to register favorites URL to be registered directly from browser.
User can active a bookmarlet - little javascript code to transfer weg page metadatas into a UDT table new item .
Do you which code to use to display value in a UDT empty form?
Régis
2008-10-10 03:26 PM
I don't know the answer to this question, it may be worth contacting the UDT core team directly in the DotNetNuke forum, thanks
