Events Module Question
Last Post 2008-10-08 04:38 PM by omorgan. 2 Replies.
mgordonUser is Offline
2008-10-02 08:35 PM
Hi All,
I am in the settings of the Events Module.  I want my editors additions, changes of events to be moderated.  There are three of us that will be moderating the Event Module.
My question is this:  In the "Moderation Settings" piece of the Module's settings, there is a field that says:
Moderator Email(s):
If you click on the question mark next to it, it says:  "Enter emails for notification when an event or enrollment require moderation."
Right!  This is what I want to do.  However, when I add more than one email address to this, it craps out on me.  I've tried the following formats:
name@pwcparks.org, name2@pwcparks.org, name3@pwcparks.org  (This craps out on me.  When I go to the next field it throws this error:
Valid Moderator Email Address required
I've also tried separating with semi-colons (;), to no avail.  I've tried wrapping ech addy in quotes.  Nopers.....no can do.
Anyone know the correct magical format for having more than one email addy in the Moderator Email(s) Field?
Mark
Mark Gordon
Webmonkey
2008-10-03 08:15 AM
Hi Mark,
That's what I would have tried as well, does anyone else have any suggestions? Otherwise I would ask the events module project team directly and see if they can give you the magic formula! - let us know if you find the solution as that will be useful to know,
Lee
omorganUser is Offline
2008-10-08 04:38 PM
What about finding the location in the SQL Database and putting entering it directly into the DB table? Also I would try entering it in again with the semi(;) I've seen it in some cases, not necessarily with the events module, where once it triggers the validator it won't go until you refresh the page, or something like that.
DNN nav issue by imran shaikh
