how to make a customized form
Last Post 2008-09-29 04:54 PM by Lee Sykes. 1 Replies.
anthony lucasUser is Offline
2008-09-25 12:18 PM
hi gays,
let me know ,how we make a customized form . i have seen registration form and how to edit it and also make a form with the help of UDT module .
Is there any other method to display customized form
2008-09-29 04:54 PM
You may want to look at modules from DataSprings for registration / forms and also XMOD for custom forms,
thanks,
DNN nav issue by imran shaikh
