Validation Failed
Last Post 2008-07-30 02:36 PM by Joseph Craig. 11 Replies.
UmaUser is Offline
2008-07-29 02:05 PM
I am registering an user thru coding
Code Sample:
NewUser.Username = txtEmail.Text
NewUser.Membership.Password = UserController.GeneratePassword()
Dim createStatus As UserCreateStatus = UserController.CreateUser(NewUser)
User is also registered properly. I  have verified the database also.
If I try to logon with this username and password, I am getting the error message as "Login Failed." (Validateuser function is returning false)
Can you let me know a way to solve this?
Uma
2008-07-29 02:12 PM
Here is a chunk of code I found in a blog posting by John Mitchell:
            Dim oUserInfo As New UserInfo
                oUserInfo.PortalID = 0
                oUserInfo.Membership.Username = GetXmlItemValue(xmlItem, "Username")
                oUserInfo.Username = GetXmlItemValue(xmlItem, "Username")
                oUserInfo.Profile.FirstName = GetXmlItemValue(xmlItem, "FirstName")
                oUserInfo.FirstName = GetXmlItemValue(xmlItem, "FirstName")
                oUserInfo.Profile.LastName = GetXmlItemValue(xmlItem, "LastName")
                oUserInfo.LastName = GetXmlItemValue(xmlItem, "LastName")
                oUserInfo.Profile.Unit = GetXmlItemValue(xmlItem, "Unit")
                oUserInfo.Profile.Street = GetXmlItemValue(xmlItem, "Street")
                oUserInfo.Profile.City = GetXmlItemValue(xmlItem, "City")
                oUserInfo.Profile.Region = GetXmlItemValue(xmlItem, "Region")
                oUserInfo.Profile.PostalCode = GetXmlItemValue(xmlItem, "PostalCode")
                oUserInfo.Profile.Country = GetXmlItemValue(xmlItem, "Country")
                oUserInfo.Profile.Telephone = GetXmlItemValue(xmlItem, "Telephone")
                oUserInfo.Membership.Email = GetXmlItemValue(xmlItem, "Email")
                oUserInfo.Email = GetXmlItemValue(xmlItem, "Email")
                oUserInfo.Membership.Approved = True
                oUserInfo.AffiliateID = Null.NullInteger
                oUserInfo.Membership.Password = GetXmlItemValue(xmlItem, "Password")
                Dim createStatus As UserCreateStatus = UserController.CreateUser(oUserInfo)
                If createStatus = UserCreateStatus.Success Then
                    responseBuilder.Append(String.Format("User '{0}' created successfully", oUserInfo.Username))
                Else
                    responseBuilder.Append(String.Format("User '{0}' creation failed: {1}", oUserInfo.Username, [Enum].GetName(GetType(UserCreateStatus), createStatus)))
                End If
Perhaps thinks like PortalID, Email, AffiliateID are necessary ...
UmaUser is Offline
2008-07-29 02:18 PM
Joe,
Thanks for your reply.
As like the sample code, I am also passing all the mandatory fields and user is also created succesfully. But when I attempt to login with this  username and system genrated password, I get the error "Login failed"
Please advice
Uma.
2008-07-29 02:20 PM
Have you tried using the "Forgot Password" link and using the password that is sent to you?
UmaUser is Offline
2008-07-29 02:39 PM
Yes. I tried forgot password also. Still login fails.
2008-07-29 02:43 PM
Are you able to login with the Host and Admin accounts?
UmaUser is Offline
2008-07-29 02:47 PM
I am able to login as host and all the registered users logins are working fine.
The only thing is that the user created thru coding is not logging in.
2008-07-29 02:57 PM
OK, then the problem is in your code that creates the user ... obviously!
If you want to post the entire snippet of code, do that or attach a file. It's hard to debug without being able to see everything.
UmaUser is Offline
2008-07-30 11:10 AM
I am pasting my code to create an user
Dim NewUser As New UserInfo()
NewUser.PortalID = PortalId
NewUser.Membership.Username = tbEmail.Text
NewUser.Username = tbEmail.Text
NewUser.Profile.FirstName = tbFirstName.Text
NewUser.FirstName = tbFirstName.Text
NewUser.Profile.LastName = tbLastName.Text
NewUser.LastName = tbLastName.Text
NewUser.Email = tbEmail.Text
NewUser.Membership.Email = tbEmail.Text
NewUser.DisplayName = tbFirstName.Text &
NewUser.AffiliateID = Null.NullInteger
NewUser.Membership.Approved =
True
NewUser.Membership.Password = "password"
If I edit the user's in Admin->User Account, I can able to login successfully.
Please let me know where the problem is.
Uma
2008-07-30 01:37 PM
You might want to look at what is returned by CreateUser.
Also, you say that after editing the user's account, you can login. What do you edit in the user's account to make this happen?
UmaUser is Offline
2008-07-30 01:57 PM
In Admin -> User Account, I have changed the password and logged in with this new password successfuly.
CreateUser() is returning success after inserting the user details into the database.
Login fails only If i try with password that I have given during creating the user.
I have tried both static password and GeneratePassword()
2008-07-30 02:36 PM
I suggest that you download John Mitchell's tool from here.  Try using it to create a single user.  See if that works.  If it does, then the problem is in your script.  If it fails, then we need to look at your DotNetNuke installation.  This will, at the least, tell us where to look.
DNN nav issue by imran shaikh
