New DNN site -old database
Last Post 2008-05-14 02:46 PM by Joseph Craig. 1 Replies.
saintXUser is Offline
2008-05-14 08:20 AM
Hello, I have made a new installation of my DNN site in a subdomain and have connected it to the data base of the old site, which is still online untill the new site gets ready.
Every time I hit a link of the new site, it jumps to the old site. Can I make some changes so that the new site works correctly?
2008-05-14 02:46 PM
You need to adjust your site's Portal Alias in the Portalalias table.  These tutorials cover that item:
DNN nav issue by imran shaikh
