Updates fail without IIS restart
Last Post 2008-05-09 03:02 PM by Lee Sykes. 1 Replies.
dp6aiUser is Offline
2008-05-07 09:47 AM
Hi all,
Often when im updating a site (i.e adding modules) the updates fail (the screen just hangs) until i restart IIS at which point the updates work fine..
Has anyone had this issue in the past?
DNN ver: 04.08.00.
Thanks in advance.
dp
2008-05-09 03:02 PM
I haven't come across that problem, thanks,
DNN nav issue by imran shaikh
