Newbie says hi, and has solpartmenu question
Last Post 2008-04-18 08:40 AM by Lee Sykes. 3 Replies.
dragonautUser is Offline
2008-04-15 08:24 PM
Hi everyone, I'm starting out with DNN and I'm having problems customizing SolPartMenu. I'd like to add a border around the root menu items (please see attached image) but no matter what I move in the CSS file, I can't get the exact desired effect. Adding a separator doesn't quite work as I want it. Please help, I've been trying this for 2 days and can't get it done. Thanks in advance.
2008-04-16 04:08 PM
anyone??
2008-04-17 01:54 AM
My only suggestion is that you use the Web Developer's Toolbar to simplify your experimentation with CSS styles. The styles for the menu should be in your skin.css file.
I just played a little and found that adding:
border: 1px solid;
border-color:#ff0000;
To the style for .main_dnnmenu_rootitem put a border around the top level menu items.
2008-04-18 08:40 AM
You may want to check:
Troubleshooting DotNetNuke Skins which outlines the techniques with the web developers toolbar and
www.skinningtoolkit.com
which lists various CSS classes used for styling SolPart, thanks,
DNN nav issue by imran shaikh
